is there a way to create your own icons for bookmark shortcuts on the homescreen?
my problem is that i dont want the text beneath all my icons, but some of my bookmarkicons are the same or dont have a special icon so i cant destinguish one bookmark from another
Sure. First using the web browser, create a bookmark for the link you want as a shortcut. Then long press the home screen and choose shortcut>bookmark.
I use Go Launcher. When you press a Bookmark icon it gives you a "replace" choice, let's you pick anything from your gallery. Easy to create your own, or download icons from a web page and use those. Go also lets you turn off labels on desktop and leave them on in app drawer.
