Apps Creating a CountDown Timer
Trying to create a simple 1 minute timer.
I want it to start once a user hits a button (in this case the button's ID is 'Tap'), and at 00:00, I want a message to popup.
I also have a reset button, when a user clicks that I want it to reset to 1:00. Thanks for any help.
Well, what have you got so far in regards to the timer? Basically, you'll want to have a data member for the lastRecordedTime, intializing it in System.currentTimeMillis() in onCreate(), then create a new TimerTask subclass and in the run() method, get the current time into a local variable, subtract lastRecordedTime from it, convert it to hours, minutes, seconds (or w/e combo of them you need), and set the text of a TextView to the result. Lastly, you'll want to set lastRecordedTime to the local variable you stored at the beginning of the run() method.
