Help Creating Folders
Aced56
Is there a way to make folders to put different apps into? Like a want a folder to keep all my games in so I have them all together and also have less screens to scroll through?
Thanks
You can do that using GO launcher, and I think other launchers offer the same function. Although there's probably a way that doesn't installing involve a whole new launcher. . .
Thanks
Hi,
You can create folders on stock home screen by pressing and holding the screen. You'll get a pop-up menu, one of the options is "Add to home screen", here you can choose "Folders", "New folder". After creating you can open it, press and hold the title section and rename it.
Is there a way that I can do a standard reply text to send to people. I want to be able to keep it to send to clients, giving instructions on how to get to my office. It was called a template on my Nokia N 95 8gb
