Hey, Is it possible to make different ringer presets on the Stylus 2024? Like save values for ring/vibrate/silent and the volume levels.
Thanks!
yes, i know i am kicking a dead thread, but on the off chance that someone may want info or the OP sees this (and i am in pain & bored)...
not sure about the volume levels, that ismost likely a global 'phone' app setting for phone calls, and i believe there are seperate volumes automatically saved for earpiece, headset (individual, each different? idk or a general one for all), and loudspeaker setting that is dictated by what volume level was used last time.
as far as the specific ringer sounds, you can specify what ringer is heard for individual callers, but i am not sure about volume control for each individual contact
either your 'phone' app or your 'contacts' app may have these adjustments available
if not, there are other utility apps out there, you are by no means locked into using only the ones that came with the device
you may even enjoy testing out some different ones that have various features
if this is not the answer or a partial answer, then something you can also try is an app from F-droid called VolumeLockr that can lock the volumes to a user setting.
(it can also allow multiple variations)
Volume locker
f-droid.org
