D
Deleted User
Guest
Hi,
I have a Samsung Galaxy Ace and I need to be able to create an audible reminder for a "to-do" (Nokia terminology), but one that will repeat itself until I intervene. The reason for this is that I may be out of the room when the first reminder sounds and I want it to repeat at defined intervals (on my old Nokia, it simply kept sounding at short intervals until I stopped it).
I am using "calendar" to create an event, as I can't find any other way of doing this.
I don't understand the event settings e.g. why I need a from and to date and time, but assume this is to facilitate a more commercial use of the calendar. I set the reminder to 1 minute, but don't really know what that does. Anyway, it only sounds once, which is not of any use.
Does anybody have advice on a better method, or have a link to a comprehensive document that would walk me through setting (repeating) reminders. Better still a free app that would do what I need.
Thanks,
Tommy
Thanks,
Tommy
