Criskelo issue with Back & Home buttons
Eric618
Member
Hey guys, I installed Criskelo last night, and the install went very smoothly. I love the ROM too. It's much better than stock, thus far. I am having two issues, though...
The battery life seems pretty poor compared to stock. Also (and more importantly), my Back and Home buttons are messed up. The Back button doesn't work at all, and the Home button functions as the Back button. The Search button doesn't work at all either.
Am I missing something clear, or is there an issue somewhere? Thanks in advance!!!
Did you use Hellraiser to install? I think Criskelo is an i9100 ROM. You are in the i777 forum.
You can run i9100 ROMs on your phone, but you have to, AFAIK, run Hellraiser immediately after flashing.
I didn't. I was unaware of Hellraiser. I ended up scrapping Criskelo altogether. I'm now using Cognition 777 R2. It's way better than stock. Because of issues I had with other ROMs, I'm not looking to change any time soon! :D
Thanks for the reply though! :)
Glad you got it fixed.
When choosing a ROM for your ATT SGH-i777, make SURE that the ROM is for this phone and not the i9100 or another flavor, and your percentage of problems goes WAY down.
