bubbasd
1stly -Novo Flame-
Christian Troy has been kind enough to release a Fire Compatible CWM AND A Fire compatible CM10! Please note that this is still in testing. Flash at your own risk.
Features (Ripped from Aurora II post)
* UbiFS (like stock roms)
* Bluetooth USB dongle support
* USB GPS support (cp210x and pl2303)
* Xbox 360 gamepad support (xpad)
* PS3 USB gamepad support (hid-sony)
* Generic / chinese (Pantherlord / GreenAsia) gamepads support (hid-pl and hid-gaff)
* OpenVPN support (tun)
* Veno congestion control algorithm
Changelog
2012-10-10
* Bump Android version to 4.1.2
* Fixed (maybe) pops during sleep
* Aurora-II: download new compatibility zip v2.0 (1.5 GHz enabled; built with linaro 4.7 and CFLAGS optimization
* Crystal: added initial support
* Other minor stuff
* Updated upstream sources
* Flame Download Compatibility Zip RC1
Instructions
Before flashing a fresh CM rom please wipe media partition with stock recovery then continue with below instructions
1. Extract and Copy CWM-5.5.0.4-fire_XX.zip (Where XX is QM or TM) to external SD card
2. Copy cm10_elf2_20121010.zip, gapps-jb-20121011-signed-ubifs.zip and fire_XX-cm10-compatibility-rc2.zip to the external SD card
3. Reboot the tablet in CWM recovery mode (Power + Volume -)
4. Select Wipe Data/Factory reset and confirm the format
5. Choose Install zip from SD card and select choose zip from SD card and select cm10_elf2_20121010.zip first.
6. Next select gapps-jb-20121011-signed-ubifs.zip
7. Lastly select fire_XX-cm10-compatibility-rc1.zip (XX is QM or TM) (You can then apply any patches if available)
8. Reboot the tablet
Issues:
Auto rotate is not fully functional.
Stock Camera app keeps crashing. Cameras are broken.
Possible minor instability. More testing is needed.
This Source: here
PS:Im only a elf2 user so i dont know anything about the Flame and others i saw this in this forum and thought to share around.
-----FILES-----
CM10 ELF II 4.1.2 ROM by christian troy here
Latest GAPPS for ELF II here
Misc Compatibility zips (these piggyback off The cm10 elf 2 rom and get flashed last.)
* Aurora-II v2.1
* Crystal v1.1
* Ramos W22 PRO v1.0 (This is not ainol but close)
* Flame in here
PS You can keep an eye on christian troys up-to-date's he post's here
Cheers.:ciao:
Note: this is one of my older topics see updated one here
Changelog
2012-10-10
* Other minor stuff
Instructions
Issues:
This Source: here
-----FILES-----
* Aurora-II v2.1
* Crystal v1.1
* Flame in here
Cheers.:ciao:
