desilynn79
heres all the good links all in one post:
recovery: ClockworkMod Based Recovery v6.0.3.7 for Prevail2/Ring
custom kernel: [Kernel][OC]rbheromax rb3 Kernel v6.0.1
safe to remove bloatware list for s3 (these are safe for ring/ prevail2 also-- i have tested myself):
https://docs.google.com/spreadsheet/lv?key=0AqTvctlW89DtdC1qVUlLeVFTV3ZOdUtDclpBdVRQOU E&pli=1#gid=0
Apps Safe to Remove from Samsung Galaxy S3 (Sprint Version, Stock Rooted) - Android Forums at AndroidCentral.com
app i use to remove bloatware- root app delete (on google play):
https://play.google.com/store/apps/details?id=zsj.android.systemappremover
stock mh5 update:
https://www.dropbox.com/s/qntbqz2pey6vy3e/SPH-M840_MH5_Stock.zip
hope this helps people
i have been told the links above for the rom etc are dead... here are the link to my dropbox where i have placed them... if you have the link you should be able to access...
custom kernel
https://www.dropbox.com/s/xdqobzic4dtc2m9/rb3-6.0.1-t1 custom kernel.zip?dl=0
custom recovery
https://www.dropbox.com/s/1uksir1jq1yttlf/CWM_Prevail2_Ring_Koumajutsu.tar?dl=0
odin 3.07
https://www.dropbox.com/sh/gsny82ygb7hxba9/AAAZSFbLWQvHt3bUWynYSlMza?dl=0
if you cant access them by copy and pasting pm me and send your emai and then save them to your computer... i hope this help yall
stock mh5 update:
custom kernel
custom recovery
odin 3.07
