I thought I knew what to do with that ZIP, but it turns out I don't.
My impatience got the better of me. I did a couple Searches, but I was not successful, my search terms must be off. Can you point me in the direction on how to use it?
TIA
Looks like I might have deleted adservice.apk. I can't find it on the DX2 with all the other bloat.
Reset my hosts file to just localhosts, no success there either.
Followed all the steps and am up and running with root maintained.
Thanks again
Don't freak about the 380 in the name. I did because I thought it SHOULD have said 418, but when I received the actual update, I saw that it had the EXACT same name.
I just saw this thread, I am experiencing the same issue attempting to update my rooted dx2. I did remove the bloat and several other programs I didn't use . Now myverizon hangs when I try to check my plan info on the "gatherong resources " screen. I want to use the sbf to return to stock to fix this problem; as well as receive the ota update , however i can't find a good link with the {sbf 2.3.4} can someone please post? Also, I have voodoo rootkeeper ,and the chinese rom manager installed, , nandroid backup working and confirmed, will I lose any combination of those by reverting back to stock via the sbf 2.3.4? Any insight is appreciated.
