Root Custom ClockWorkMod Recovery System!!!
Rookie407
INFORMATION
Quote from: BobZhome - AC Forums
I'm posting this under Optiums Slider because the Q does not have it's own forum, also it is very close to the Slider in that they both have the gelato board.
Here is CWM v5.0.2.7 for the Q: LGL55C_recovery.img
Un-zip flash_image.zip and place flash_image(no extension) on the root of your SDcard, along with LGL55C_recovery.img that you just downloaded.
Then to install, in "terminal Emulator" on your phone, type:
su
mount -o remount, rw /system
cp /sdcard/flash_image /system/bin
cd /system/bin
chmod 777 flash_image
flash_image recovery /sdcard/LGL55C_recovery.img
reboot recovery
Special Thanks to: Mark_One for the files and info that was needed to make this recovery!
I didn't write these i just copied and quoted the Authors from another forum But i hope this Information Helps you Guys with LG Q from ST out
