PaterMark
I'm trying to put a Layout into a MenuItem, which works, but it seems that the layout is placed next to a space reserved for the icon and title.
This is my output:
And this is the code used for the menu:
menu.xml:
drawer_list_item.xml:
As can be seen from the output, the counter TextView is not displayed on the screen (due to the layout being pushed to the right).
Does anyone know a fix such that the relativelayout starts at the same position a regular MenuItem would start?
Thanks in advance.
This is my output:
menu.xml:
Code:
<?xml version="1.0" encoding="utf-8"?>
<menu xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto">
<item
app:actionLayout="@layout/drawer_list_item"
android:id="@+id/nav_item_inbox"
android:visible="true"
<item android:title="Using a regular MenuItem"
android:id="@+id/nav_item_sent"
android:icon="@android:drawable/ic_input_add"
</menu>
Code:
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_height="48dp"
android:background="@drawable/temporary_border_layout">
<ImageView
android:id="@+id/icon"
android:layout_width="25dp"
android:layout_height="wrap_content"
android:layout_alignParentLeft="true"
android:layout_marginLeft="12dp"
android:layout_marginRight="12dp"
android:contentDescription="Test"
android:src="@android:drawable/ic_input_add"
android:layout_centerVertical="true" />
<TextView
android:id="@+id/title"
android:layout_width="wrap_content"
android:layout_height="match_parent"
android:layout_toRightOf="@id/icon"
android:minHeight="?android:attr/listPreferredItemHeightSmall"
android:textAppearance="?android:attr/textAppearanceListItemSmall"
android:textColor="@android:color/black"
android:gravity="center_vertical"
android:paddingRight="40dp"
android:text="Using the layout as MenuItem"/>
<TextView android:id="@+id/counter"
android:background="@drawable/counter_bg"
android:layout_alignParentRight="true"
android:layout_marginRight="8dp"
android:textColor="@android:color/white"
android:text="3"/>
</RelativeLayout>
Thanks in advance.
