Custom LeOS 2.5 is out
Dear pino,
i've alrwady downloaded the leos 2.5, z root, root explorer and google app. i dont realy understand technical term if you could guide in the process as i have a 3gw101 ,leos 2.0 in i think. i ve seen other How to Install Leos 2.0?, PC driver installation error and GoogleApps/Market with LeOS 2 beta but noy realy understanding root and i dont know if my phone is rooted.
Plz any help adn detailed xplain will be most welcome.
Dear pino,
Jake,
Try thi guide with pictures:
http://androidforums.com/lenovo-lephone/316312-leos-2-0-google-install-guide-pictures.html
how to change the theme?
If you are using the Lenovo home screen it is in the application area under theme manager. Otherwise if you are using something like LauncherPro in the top right of the screen oposite the time you will see the circle for the original home screen applications you need to press that and you will find them manger.
Hello I dont't understood "application area under theme manager". I'm not able to find any theme manager application I have last LeUI 2nd edition. Please help me.
thanks
