Hi,
I downloaded the Ring Extended App (which doesn't exactly appear as an App but rather adds a selection onto which sounds you want to choose from when deciding what ringtones to select-either Android sounds or Ring Extended sounds).
With that in mind, how do I uninstall it?
Why do I want to uninstall it?
Because the custom Notification sound effect I have selected doesn't seem to want to engage when a Notification comes through.
Let me see if I understand this correctly......Notifications come through and appear in the upper left hand corner of ones phone, right? They can be downloads one has taken, or advertisements, or updates pending, or phone calls missed, etc. You get the idea, right?
Is that a correct understanding of Notifications?
Well then, shouldn't there be an associated Notification ringtone that sounds off when any kind of notification comes through?
That is my understanding of the situation. Am I in error about that?
Please tell me how I can correct this malfunction of the notification sound effect ringtone to make it sound off every time a notification comes through......or else tell me how I can uninstall Rings Extended permanently, and perhaps download a better functional App that will let me customize my chosen sound effect.
Thanks and I hope someone can help me.
PS This is my first question and I am learning my way around this Forum-so much to learn. This Forum is big!
