Custom Recovery
Do you have the Rooted 2.1 installed or one of the leaks because if you have a leak you cant flash a rom that has su enabled because it will not pass the Verification Check
You need to back out of this thread and scroll up to the Root sub-forum. Those folks in there can answer your questions and you will also be in the appropriate forum. Good luck with your issue.
