Root Custom rom_help!
HelpaDroid
Hello i am HeplaDroid.
I am very noob to android flashing etc. I have a LG P350 | Rooted device, With android 2.2 Froyo. I am willing to install custom roms on my device. As i am new i do not know the procedure. Please help me through?
Thanks, HelpaDroid
Thanks, HelpaDroid
okay i will start with you need cwm download rommanger on the android market you need to get into the bootloader through recovery how ever it is with your device i do not know look into the root guide of the forums. put the custom rom on the root of your sd card and in recovery do this as in order please. factory reset,clear cache,in advanced go to wipe dalvik cache in mounts and system go to format system. then after you format the system choose install zip from sd card find the rom zip and install after you have installed it reboot the phone. then wait the phone will seem like it takes so long to reboot at the bootanimation its okay this is normal.
find the stock image in case of a bad flash on that custom rom you choose and back up with astro file before you flash that custom rom my opinoins really so be careful okay. you want to know how to get back to stock if something bad happens i suggest you find the means to do so and good luck to you.
I have tried this many times. when i boot into recoverymode it just wipes the phone? then powers on, i have tried to get in through Emulator etc, it still wipes it and will go straight to power on, if that all made sense? :L
So i have to Factory reset?
yes on every custom rom you have to factory reset and clear cache and in advanced clear dalvik cache. its good practice and enjoy. i do not know your device but i know how to flash its like usb ports on phone ha its always the same. i do not know how to get into your bootloader recovery is the issue.
your in the bootloader and not the recovery bootloader in the just plain bootloader it will not install custom roms just wipe data and reboot. in the recovery you can install custom roms and wipe data etc.. there is a difference and i do not know how you can get into your recovery now sorry.
Guys,
I've moved you from the Android Lounge over to the LG Optimus Me P350 all-things-root forum.
You'll get more views and feedback from the experienced P350 root folks here, too.
Cheers and good luck!
-SA
if you want cwm recovery on your phone you need first this drap recovery click her after install drap recovery download p350 cwm recovery from this link ok now reboot your device into drap recovery and flash this cwm recovery. only this way to install cwm on p350
