So now we have 4 Custom ROMs for Galaxy Y:
Creed's ROM
Thread: @XDA
Download: Megaupload Source
InstructionsScreenshots
Creed's Rom v1.0 Features:
Known Issues:
InFected ROM
Thread: @XDA
Download: InFected v2.3
Q&A Thread: [InfectedRom]Q&A - xda-developers
Features:
How to install:
BancetDEV's ROM
Thread: [ROM][Samsung Galaxy Y GT-S5360] bancetDEV-beta
Download: Multiupload Source
Odin: Odin
USB drivers: Samsung
Features:
How to install:
OPTIONAL(Partition SD card)
Cranium ROM
Download: Multiupload source
Root: @XDA
Features(not all included as yet):
How to install:
Creed's ROM
Thread: @XDA
- Adb/Hard Root - Access to Android Commander
- Soft Root- SU
- Pre Deodexed
- ZipAligned
- Maps With WorldWide Navigation
- Bloatware Removed
- BusyBox Support
- Init.d Support
- 30+ Init.d Script For Faster Peformance
- Message App:
-No Auto Sms To Mms Conversion
-No Receipient Limit
-Built In 5 Theme - Touchwiz App(Samsung Home) :
-Transparency Level Increased
-Alphabetical Auto Arrange
-ICS Style Dock and Icons
-Landscape Orientation Intoduced - Full System Ice-Cream Sandwich Themed
- Auto Brightness Option in Display
- ICS Icon Pack
- ICS Notifications and Audio Ringtones
- ICS Music Player
- Boot Animation Enabled
- Custom Boot Animation Added
- Custom Power On Sound
- Reduces Startup Time ~Less Than 13 seconds
- 14 Status Bar Toggles
All 5 From Samsung(Wifi,B/T,Soung,GPS,Orientation)
-Data
-Lockscreen-Off
-FlashLight
-Shut Down Options
-Reboot,Recovery & Download modes
-Airplane Mode
-Brightness
-Auto Synchronise
-Screen Timeout
Known Issues:
- Bootanimation bug
- Missing apps
pratyush.creed said:The Rom Dosnt Seems to Work Well .. Here's The Solution :
Download This(A Fix-With Everything Working): DXKL2_Theme_ICS.rar
Copy It Into the SdCard Like This Structure : sdcard\clockworkmod\backup\2012-01-13.19.07.30
Now Open Clockwork Mod and goto Backup and Restore ...and Restore This Rom !! Now Status bar and Everything Else Would be working...but swype gives a Force Close so use Root Explorer and delete it From /system/app.
InFected ROM
Thread: @XDA
- fuju binaries.
- some major responsiveness improvement under heavy load.
- calculator fix.
- replaced music app with google one(ics)
- Autoroot.
- Init.d should be now functional
- Fixed Camera
- Themed with UOT Kitchen.
Features:
- Based on DXKL2
- De0dexed
- Zipaligned
- CM7 Music
- DSP Manager
- Auto Zipalign at Every Boot
- init.d & Busybox Support
- Torch! (Useless, as uses camera light)
- Sqlite3 added
- sqlite.so & ssqlite_ini.so from ICS(Improves Performance)
- Removed Samsung Bloatware
- LauncherPro
- Fast & sexy!
- Keyboard Force Close error.
How to install:
- Download The ROM
- Download Skin's recovery: <(Link after XDA is up again>
- Boot into recovery mode(power off, then vol+ + home + power)
- "apply update from sdcard"(use volume buttons to navigate and home button to select)
- choose Skin's recovery(Skin1980-GT/S5360+CWM.zip)
- Optional: backup and restore>backup [Recommended](press back)
- wipe data/reset, wipe cache partition, advanced>wipe Dalvik cache(press back)
- "install zip from sd"
- choose the ROM zip
- done
BancetDEV's ROM
Odin: Odin
Features:
- DT Apps2SD pre-installed.
- Rooted
- init.d subsystem.
- Re-odexed (optional) and zipaligned for speed and save space in /data.
- Added busybox and sqlite3.
- Updated/added AdwEx, Quickboot
- Removed unwanted apps (Swype,....)
- SD card error(shows up sometimes)
How to install:
- Download Skin's recovery to phone: <(Link after XDA is up again>
- advanced>Partition SD Card, choose <1024 and then 0M
- Download ROM and Odin files.
- Get into download mode: (vol- + home + power)
- Use Odin to flash: Take Instructions from here
- Hard Reset using code(dial) *2767*3855#
Cranium ROM
Thread: @XDAsakindia123 said:i decided to end the rom.I will build kernels only.
Root: @XDA
- Pre-rooted
- Fully de-odexed and zipaligned
- Highly minimalistic(81 MB free in /system!)
- init.d support and some ramdisk tweaks
- Tweaks inspired from Android 4.0 {Gadgetcheck}
- Worldwide APN list
- Removed either PowerOn or PowerOff sound(i forgot )
- Better GPS + FasterFix included
- CRT EFFECT + OVERSCROLL GLOW
- ICS Animations+ICS ROBOTO FONTS
- AdBlock integrated :|
- BusyBox and SqLite 3
- Some cool apps
- MIUI lockscreen chooser
- No-Frills CPU control
- AOSP gallery
- Quick Office replaced with Think Droid .
- Updated SuperUser binaries
- ADW launcher as default
- DSP manager from Cyanogen Mod 7
How to install:
- Download The ROM
- done
- Optional: Root again
