whitworth
I've tested out the custom vibration pattern for calls which works nicely, but for some reason the vibration pattern won't work for SMS messages or notifications. All I'm getting is a flat vibrate that lasts for a second.
Does anyone know if thats how the notification vibrations work or can you pick different vibration patterns for the notifications?
Thanks
Thanks
) that as the notifications sound option comes after the vibrate options, that they only refer to calls.
