Download ES File Explorer. Open it up and you'll see a folder on your internal SD called GOSMS. Longpress on that folder and you'll see a tiny garbage can.. delete the folder.
Then go into your phones Settings > Apps > Downloaded and locate Go SPS Pro. Tap on it to open and then tap on Clear Cache and then tap on Clear Data.
Just reiterating; this will reset Go SMS to default settings.
okay so why am I being led to other apps when the phone as it is should do this itself? ...
