Custom sounds
Rudles
I now have a Galaxy S5 and I want to add custom ringtones/notification sounds. I know that on the S3 there was a way by creating new folders and copying them into those folders from my computer. Does this work with the S5? Does anyone know/remember where to create those folders?
as far as im concerned you can put them in any folder you want, as long as the music player can readthem, you can certainly make then into a ringtone/notification sound for sure!!
If you use Ringdroid or Ringtone Maker they'll put it in the right folder automatically. You can use any mp3 or make your own recording.
