custom tones for contacts?
Yes, you can for ringtones for Contacts. Not sure about SMS since I don't do that. Took me a while to figure out custom ringtones per contact.
When you have a contact open, click the Menu button and then select Options. From there you can select a ringtone.
Thanks for the tip! I have been trying to set custom ringtones all day.
It never occurred to me that it wouldn't be under the "edit contacts" pick.
They never tell you how to do it in the users guide either.
