Hi!
Last week I got really tired of post paid BS so I switched to prepaid. The Volt was $59 at Best Buy for Sprint... So, why not. Anyway, I am a long time member of XDA, but they seem to be lacking on the Volt, so I'm here and I like to tinker.
I have done a bunch of tweaks and mods to the Volt so far and I thought I would share. All the tweaks listed are currently in-use on my phone.
**You will need root access for most of this stuff**
system/build.prop (just add this to the end, battery life is amazing)
Reclaim Space (If you did not notice, the ROM on the phone is built for a number of carriers. This removes duplicate garbage.)
I'll add more soon.
Code:
# Niteryder's Tweaks
#Disable Boot Animations
debug.sf.nobootanimation=1
#Disable Android Logging
profiler.force_disable_err_rpt=1
profiler.force_disable_ulog=1
logcat.live=disable
ro.kernel.android.checkjni=0
ro.kernel.checkjni=0
ro.config.nocheckin=1
#Google DNS
net.dns1=8.8.8.8
net.dns2=8.8.4.4
net.rmnet0.dns1=8.8.8.8
net.rmnet0.dns2=8.8.4.4
net.ppp0.dns1=8.8.8.8
net.ppp0.dns2=8.8.4.4
net.wlan0.dns1=8.8.8.8
net.wlan0.dns2=8.8.4.4
net.eth0.dns1=8.8.8.8
net.eth0.dns2=8.8.4.4
net.gprs.dns1=8.8.8.8
net.gprs.dns2=8.8.4.4
# Net Speed Tweaks
net.tcp.buffersize.default=4096,87380,256960,4096, 16384,256960
net.tcp.buffersize.wifi=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.umts=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.gprs=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.edge=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.hspa=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.lte=524288,1048576,2097152,5242 88,1048576,2097152
net.tcp.buffersize.hspda=4096,87380,256960,4096,16 384,256960
net.tcp.buffersize.evdo_b=6144,87380,1048576,6144, 87380,1048576
#Save Battery
ro.ril.disable.power.collapse=0
ro.config.hw_power_saving=true
power_supply.wakeup=enable
ro.ril.sensor.sleep.control=1
proximity_incall=enable
pm.sleep_mode=1
ro.ril.power_collapse=1
wifi.supplicant_scan_interval=180
ro.mot.eri.losalert.delay=1000
#Better Scrolling
windowsmgr.max_events_per_sec=150
ro.min_pointer_dur=8
ro.max.fling_velocity=12000
ro.min.fling_velocity=8000
#MOAR RAM
dalvik.vm.dexopt-flags=m=v,o=y
persist.service.pcsync.enable=0
persist.service.lgospd.enable=0
#More Volume Steps InCalls
ro.config.vc_call_steps=20
#Call Quality Bump
ro.ril.enable.amr.wideband=1
#Fast Boot And Reboot
persist.sys.purgeable_assets=1
ro.config.hw_quickpoweron=true
Code:
space.sh - <<This is for Sprint Only.. I'll update this to cover all carriers and explain it better.
I'll add more soon.
