Custom Vibration
ai_02byEJFNsbuhWF3NIJl6TCtp-N6ym4inkvMiUCteNALYeDvTC3gU9771JuxOH8_ya
Take control of your phone's vibration system drawing a line on the screen.
You can create new points by pressing anywhere on the screen, delete them by pressing on them or move them to create the line you want.
To obtain a vibration of normal intensity and constant draw a straight line at the bottom.
A straight line at the top will have a very slight vibration
