Help Customizing the lock screen
emeril322
Member
Is there any way to customize the lock screen to change the color/style of the font and what is shown up on it?
Also (had a 2nd question but didn't want to make a new thread just for it) what's the best media player to use in place of the default one?
Thanks.
Hi,
There is no way to change anything on the default lockscreen, but there are loads of 3rd party apps that can replace the default one and be configured. Go Locker for example.
For media, I am not sure if you mean movies or audio. For audio I use PowerAMP and for movies VPlayer.
Hi,
Cool thanks, sounds good. I'll check those all out. :D
Edit: When I downloaded GO Locker it made me download GO Launcher EX as well. I already use Launcher Pro as my launcher app and I'm worried there might be some conflict issues with all of these on here? I really like Launcher Pro and don't wanna switch away from it either.
Also, are there many more options with adjusting my locked screen (while using GO Locker)? I'd like to move the position of the date/time and change the color of the font if possible.
That's $2.99, and sadly I was looking for a free app (all apps should be free!).
That's how I felt at first but its a pretty sweet app, definitely worth the money. Ive tried other lock screen apps and I always come back to this one.
Also, apps are the results of developers spending time to make these awesome apps for us. Hard work should be rewarded somehow right? :D
Just IMO ;)
