Root CWM 6.0.5.1 [LG Ultimate 2]
SuperR
Android Expert
Recognized Developer
DISCLAIMER: By using this recovery, you agree that you are the only one responsible for anything good or bad that may occur. Use at your own risk.;)
Built from source for the LG Ultimate 2
Choose an install option below:
Install IMG with flashify:
  1. Make sure your phone is rooted.
  2. Download CWM-6051-w5c.img
  3. Install and run Flashify.
  4. Make sure you hit “Allow” when Superuser request window pops up when opening the Flashify app.
  5. Choose “Recovery image” for recovery images.
  6. Choose the file you want to install by selecting “Choose a file”.
  7. Choose one of your file explorer apps. If you don’t see any, download and install ES File Explorer
  8. Browse your storage and choose the IMG file you downloaded earlier.
  9. Choose “Yup”.
  10. Enjoy!
Install flashable (only if you already have a custom recovery):
  1. Download CWM-6051-w5c.zip to phone.
  2. Reboot into current custom recovery.
  3. Flash zip.
  4. Enjoy!
Thanks to the following:
@elisam98 - for base device tree
@edodson84 - for testing and motivation
@rcunningham - for testing
Hey gentlemen, I have clockworkmod installed, what button-combination do I use to enter it? Thanks
There is none. You need to get into it from Flashify by pressing the "Reboot recovery" option.
You should use TWRP because if you press and hold on the power and volume down then release the buttons once the phone vibrates and push on them again you will get fact reset. Just say yes to all and it will boot into TWRP and it won't wipe.
rcunningham thanks for the reply - basically you're saying that twrp is preferable because it can be entered by pressing keys at start whereas cwm cannot?
also which rom would you recommend? i have to do some traveling in a couple weeks so i need to get this phone up and running stably before that time comes.
thanks
thanks
Yes TWRP is better to use. And as for ROMs, I have used all and made one of them so you can use any of th them. You can find a list of ROMs on the LG Ultimate 2 Recovery Tool thread. I reccomend stock at the current time but once I get time I would recommend the G3 ROM (Yes I made it but I don't want to advertise to much) because it will continue to get updates for the next 6 month's where as stock and the UltaLolli ROM won't get any more updates. Thoose are just my thoughts and ideas. Here is the page with all the ROMs: http://androidforums.com/index.php?threads/919560/
