Root [CWM] CWM Based Recovery For Micromax A56 And A57 Ninja
sahil11
Good News Working CWM For Ninja
I Am Not Responsible For Any Problem
Instructions:
1.Enable USB Debugging by going to Menu -> Settings -> Applications -> Development - Enable USB Debugging.
2.Download the CWM Recovery file from
Post:2
3.Make Sure Ninja Drivers Install In Your PC.
4.Tutorial To flash CWM Recovery On Micromax A56 & A57
Using ADB/Fastboot: Follow commands while device is connected with PC in USB Debugging Mode
pen Command Prompt and locate your .android folder that contain the copy of above Recovery Image. (Mine is C:/Android/A57_CWMR.img)
C:\Documents and Settings\ViOLET R>cd c:\android
C:\Android>adb devices List of devices attached Micromax-A56 device
C:\Android>adb reboot-bootloader [Hold Vol- while doing this]
C:\Android>fastboot devices COOLPADA7019 fastboot
C:\Android>fastboot erase recovery erasing 'recovery'... OKAY [ 0.109s] finished. total time: 0.156s
C:\Android>fastboot flash recovery Custom_recovery.img sending 'recovery' (4436 KB)... OKAY [ 0.406s] writing 'recovery'... OKAY [ 0.813s] finished. total time: 1.219s
C:\Android>fastboot reboot rebooting... finished. total time: 0.016s
You are done Now Reboot into Recovery using VOLUME+ and Power Button Operation. Enjoy Method
Credits:-
1.Sahil Deep (ME) For Porting To A57
2.Dhinesh Kumar (Tester)
3. Jyothis Thaliath (Tester)
4.Voilet Edges For Tutorial
5.4pda.ru Users
How to flash cwm recovery on ninja 2 & 3 ? Video Tutorial By:- Dhinesh Kumar
ScreenShoot From Attachment
Source:-
http://forum.xda-developers.com/showthread.php?t=2073337
Instructions:
Post:2
Credits:-
4.4pda.ru Users
Source:-
here it comes, an alternative for flashin the recovery images just like THAT ;), click that facebook link :P
Facebook
Instructions:
Post:2
Credits:-
5.4pda.ru Users
Source:-
hey frnd...my fastboot device is not listed(micromax a57)
what should do........plz answer me!!!!!!!!!!
2.Download the CWM Recovery file from Post:2
5-copy ADB/Fastboot and adb_usb.ini in the .android folder and Follow commands while device is connected with PC in USB Debugging Mode
6-Press Shift And Right Click and open Command Prompt from C:\Users\Administrator\.android and copy the Recovery Image(a57recovery.img)
type this commands
7-adb devices
Hold Vol- Key and continue type commands
8-adb reboot-bootloader
9-fastboot devices
10-fastboot erase recovery
11-fastboot flash recovery a57recovery.img
12-fastboot reboot
Finally ported cwm to my ninja 3.0 !!!! Now i am waiting for a suitable tested custom rom thats less ram consuming and has improved audio than the stock rom !!!!! If u have any custom rom for nina 3.0 which has been tested ,please inform me at ishaan3731@gmail.com ..
At present i have rooted my phone and uninstalled almost all pre-installled apps : i even substituted my gallery with quickpic(its fast and clear than basic android gallery)!!! I have done same with basic calculator,notepad,music player and video player.... Phone works fine but i think i need a good custom rom !!!
