Root [CWM]ProjectPanda Recovery
[BOX=CodeName]Please note that the next version of ProjectPanda Recovery will be codenamed SandyNY out of respect for my home state.[/BOX]
PURE ProjectPanda Recovery
Please read entire document before flashing. According to CyanogenMod rules, I am required to tell you all that this is an unofficial port of ClockWorkMod, and you all are supposed to read the whole document under this:
The official bugtracker is located HERE
Scroll down to post #2 for changelog, post #3 for installation guide, and post #4 for download links.
CyanogenMod is a free, community built distribution of Android which greatly extends the capabilities of your phone.
#Standard CM Disclaimer;
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up or hard bricking your device, I will laugh at you.
Please post bug reports on The Panda Project issue tracker for these builds. These are UNOFFICIAL Nightly Builds of ClockWorkMod for the LG Viper 4G LTE (LGLS840). I repeat this is an unofficial port. If you post issues on the official CyanogenMod bug tracker, they will laugh, and delete it. Post all issues in The Panda Project tracker located HERE.
Credits to Developers:
The entire CyanogenMod team. You guys are awesome!
Lmoore and Wormy for the installation guide.
All my testers (Thanks Everyone)
Private Testers Credits:No testers yet.
If you would like to contribute to the development of this ROM, please PM me. If you don't PM me back within a timely manner after I reply to your intial PM, I will assume you have forgotten how to use Tapatalk, and is no longer worthy of testing.
All source code is available at https://github.com/rnorris97/ . If you'd like to to contribute to CyanogenMod, checkout the device tree,https://github.com/rnorris97
Device Tree Source code including Gingerbread kernel source is now available https://github.com/rnorris97/ for everyones viewing pleasure.
What Works:
My guess is EVERYTHING.
Known Issues:
DOES NOT REBOOT. ( Unsolvable at the moment )
Legacy Releases
1.0.0 - Not released to public.
1.1.0 - Intial Release to public.
2.0.0 - Dead on Arrival.
3.0.0 - Dead on Arrival.
4.1.0 - Fixed graphics and most of the buttons.
4.1.1 - Fixed graphics, moved to CWM Touch, all buttons fixed, mount points correct.
4.1.2 - Pulled.
5.0.1 - Fixed graphics, buttons corrected again, mount points correct.
6.2.0 - Minor CyanogenMod repo updates...
SandyNY - Major code changes, CyanogenMod repo updates, source code made available on ProjectPanda GitHub.
Installation Guide:
If on Linux or Windows:
adb push recovery.img /data/local/tmp/recovery.img
adb shell
su
dd if=/data/local/tmp/recovery.img of=/dev/block/mmcblk0p13
Is this flashable with the ICS update? The reason I ask is because I followed the instruction exactly but when I either use my reboot to recovery app or run the adb reboot recovery command, I boot up to a blue screen that says Enter the fastboot...
Long time no see!
and it won't do anything and the only way to boot up the phone is to do a battery pull.
Long time no see!
ICS killed compatibility...working on it.
Long time no see!
It's been discontinued.
