Root [Cyanogen6.1.3]gingerbread[v01] - Fully Camera Working!!!
rendeiro2005
Hi all.
This is a new MOD-ROM based on Froyo with Cyanogen 6.1.3 and gingerbread theme. Hope you like it and give some feedback;)
I WILL NOT RESPOND TO ANY BOOTLOOP PROBLEMS! THIS IS DUE BASEBAND VERSION PROBLEMS!!! CHOOSE YOUR BASEBAND HERE
THIS IS FOR 54 / 55 & 58 BASEBAND ONLY!!!
YOU SHOULD INSTALL THIS THROUGH xRecovery.
IF YOU`RE NOOB AND DON`T KNOW WHERE TO START PLEASE GO HERE.​
Included/changes:
- CM Settings 6.1.3;
- Complete ROM with gapps included;
- Gingerbread Theme;
- Chrome to Phone;
- ChromeMarks;
- Spare Parts;
- Toggle2G;
- MIUI Animations;
- Fonts changed to Ubuntu;
- AnReboot;
- Astro File Manager Lite;
- Return to Android stock camera;
- GoodMorning Alarm Clock;
- XDA app;
- build.prop with LOTS of tweaks for better battery and smoothness;
- Build in Sysctl Config;
- Blade Wifi Fix;
- Flash Player (must enter on market first to upgrade);
- MUIU Keyboard;
- Wipe all unnecessary files (i.e. ringtones, notifications, etc, etc...)
note1: if any of these are payed apps please pm me and i`ll remove them ASAP. Thanks;)
note2: facebook will not update. i remove that so that you won`t loose the "black" look.
Working
Everything
Known Bugs:
This has been more than discussed and i won`t respond to any post regarding this.
- Camera/Camcorder doesn`t fully function. You may try 3rd party apps.
Instructions:
- Make a backup (if you want to);
- Factory Reset (Full Wipe);
- Wipe cache partition;
- Wipe Dalvik Cache (Advanced options > Wipe Dalvik Cache);
- Wipe battery stats (Advanced options > Wipe battery stats);
- Install [Cyanogen6.1.3]gingerbread[v01].zip;
- Reboot;
- Let him reboot one more time and you`re donne;
- Go to Settings > CyanogenMod Settings > User interface > Tweaks extras > Select a theme > Gingerbread;
- Press Menu > More > ADWSettings > Backup & Restore > Restore ADW Settings & Desktop (then make your own changes);
- Donne. Enjoy;)
Screenshots
Download Links
Camcorder Fix
Camcorder Fix - Fully working Camera and Video
If you want to restore Ringtones press HERE
If you want to restore Notifications press HERE
If you want to restore Live Wallpapers press HERE
If you want sonyericsson ARC sound files press HERE
i have installed this ROM but i would like to get into the service menu but the normal code home, back, back, home, back, home, home, back doesnt work. any other way i can get into it? also i tried downloading the HTC keyboard and that just force closes on me. and one last thing. how do i change back to me stock theme? complete noobie at this.
type on phone:
*#6436#* or *#6463#* can`t remember exactly.
try to get the last version of HTC work with me
to change theme just search for any you like. just make sure it`s for x10 lol
Sweet looking ROM!! Now I'm torn between trying this or your other CM ROM. Why do you do this to me? :(
plz clarify me that is it just flash problem or it cannot take pictures also...??
only LED doesn`t work.
HERE is the fix for that
In case you haven`t download rom yet the one on 1st post is already with everything working;) so there`s no need to apply ANY fix;)
okk installed it look awesome but u hve putted adw standalone and i hve adwex can i install it through astro..???
PS: i knw a n00b ques but can u plz tell me how to get these statistics..??
what resolution HTC keyboard did you use? i have tried v27 froyo high res and just v27 high res. they both force closed on me, any thing to do to get them to work?
i get that after install all my apps and after a few hour after all system settle down on 2nd run.
yes you can use EX perfectly
strange...
try this if i can get the problem.
copy all HTC reference from system\app to sdcard
delete those references on app folder
try to install
only just seen this (not sure why, i must have been slacking!)
i see its based on beta4 so i assume the camera works aswell as that one.
i will give this a try as it looks good and nothing out has been able to sway me from beta4 yet :)
This will be the one
Hahahaha;)
getting FC when clicking on system tutorial...:O
PS : getting FC on Music player sometimes..!
Cool ROM, but why is it in the Rooting section, I almost didnt see it? I guess this is where alot of the themes are getting placed now?
I was being stupid i wanted to install [Cyanogen6.1.3]gingerbread[v01] so i changed my baseband and in the settings it said unknown baseband i thought it said that because i my firmware wasn't updated to [Cyanogen6.1.3]gingerbread[v01] so i went on with the normal installation everything went fine it booted up i got to the lock screen and everything was fine but it freeze's after a bit and reboots then everything all over again
Also i got as far as going to my settings but it still said baseband unknown
and if it helps i was using Eminence_v1.2 if that helps
Please help i know i was being stupid but i would appreciate any help i can get
Thanks
EDIT
I believe i fixed it just reinstalled the baseband
I'm on firmware 2.0.2.A.0.24, baseband 2.0.46(Eminence ROM) right now. Can I follow the instructions at the beginning of this thread or do I need to get onto something more standard first?
Thanks
