CyanogenMod 10.1.3
maxmaxter
Member
Flashed the new stable cyanogenmod 10.1.3 with JB 4.2.2 a couple days ago. So far working flawlessly. Battery is good (I do see some CPU usage every so often when on sleep... up to 200 MHz, probably because of connection to google servers) I highly recommend to use this ROM if you are not happy with your current one, or if you want to try something new. It is smooth as silk. There are 2 things that I REALLY like: 1) the lock-screen has "fancy" widgets now. They are REALLY cool. Totally different to previous android widgets. 2) the stock message app performs very well with the iPhone group messaging. No need to be installing handcent or go SMS (which work ok, but not perfect).
Happy Flashing! :rolleyes:
