SilentR3venge
Member
I apologize if someone found a simpler method.
- Root and flash the CM11 Rom. backup boot.img
- http://www.filedropper.com/cm-11-20141109-unofficial-ms323
- change build.prop #persist.radio.multisim.config=dsds
- reboot
- Flash https://db.tt/Kr5geKwB cm11.zip for full storage
- Reboot
- Make sure developer options are turned on and your pc is authorized.
- Not sure but my device doesn't let me boot zippy kernel so with the bootloader locked flash https://www.mediafire.com/?gf8bb7q9iacp1do Zippy Kernel 2.2
- Upon reboot The LG logo you will be able to adb shell into the device. Reboot recovery (works 2nd try)
- flash the boot.img or use the boot.img in that you had originally uploaded below
- reboot and enjoy gps.
