Root CyanogenMod 12.1 (CDMA) (LTE) [ALPHA]
original post: http://forum.xda-developers.com/moto-e-2015/cdma-development/rom-cm12-0-moto-e-2015-lte-t3086497
*This is not my work! just a copy/paste from xda*
all credit goes to the original dev whos working on this rom.
REMEMBER TO MAKE A NANDROID BACKUP OF YOUR WORKING PHONE.
REMEMBER THAT THIS IS A TESTING VERSION.
Instructions For Flashing First time
  1. Reboot to recovery.
  2. Factory Reset. (wipe data,cache and dalvik cache)
  3. You should also wipe system.
  4. Flash the zip and reboot.
Instructions For Upgrading from Previous Nightly/RC/Stable/Milestone
  2. wipe cache and dalvik cache only .
  3. Flash the zip and reboot.
Current work process
We are working with @percy_g2 in order to bring CM12.1 up.
I'm working on the XT1524 and the following status as only been tested on this device.
Percy_g2 is working on the xt1521
This build works on XT1521, XT1523, XT1524, XT1526, XT1527
CAUTION Flashing build from 20150503 Seems to cause problem on the CDMA version
This thread is a copy from Scritch007 cm12 thread.
This thread will focus on the CDMA issues. All other ROM related issues should be posted to the main thread.
Status
Working
* Speaker OK
* RIL (voice OK, sms OK, Data workish no LTE)
* Camera (front OK, back OK)
* Video Recorder OK both
* Playing video recorded with the camera OK
* Auto rotation OK
* Airplane mode
* Bluetooth (detected another phone, but not tested completely)
* Wifi
* GPS
* FM
* Led notifications (Only when plugged)
Not working
* Skype issue
* Some issue in WiFi with DHCP but it depends of unknown (yet) parameters
* SEPolicy set to permissive
* Probably other stuffs
Reporting Bugs
  1. Tell which version you are on
  2. Tell which phone you are on
  3. Provide logcat
  4. Provide DMESG
  5. Provide a way to reproduce the issue
Binaries
Roms can be found here
Sources
https://github.com/Motorola-Cyanogen...otorola_surnia
Credits
  • CyanogenMod
  • cybojenix
  • Motorola
  • percy_g2
  • android_device_yu_tomato guys
  • JoshTheAndroidUser for testing the XT1526
XDA:DevDB Information
CM12.1 for moto E 2015, ROM for the Moto E 2015
Contributors
JoshTheAndroidUser, scritch007, percy_g2, jelixis
ROM OS Version: 5.1.x Lollipop
ROM Kernel: Linux 3.10.x
ROM Firmware Required: TWRP Recovery
Based On: CyanogenMod
Version Information
Status: Alpha
This is just a copy and paste from @scritch007 over on XDA. LTE works only on the Boost variant only and all the gsm variants. We've been trying to solve the CDMA issue for a while and we're getting there. If there are any CDMA guru's out there and you have some ideas please let us know. [emoji106]
