for those of us already on cm5 and want to try out cm6 do we just start from the bit that explains how to install cm6 or do we need to do anything before that?
i didnt know about the backing up apps to google thing..how do you set it up?
Go in Setting/Privacy.
Check "Back up my data" to backup your apps and settings in your google account on synchs.
Check "Automatic Restore" so that next time you setup your google account (after a wipe or a factory reset) it will pull all your settings and install your apps when it synchs back with the server.
I just got a post E911 Dream from a friend and I have been following your guide: Rogers post E911 Magic to CM 5.0.7 (Android 2.1) with Dream E911 Radio The GreatBigDog Report
Trying to do a post-E911 Dream as well, but the RUU exe doesn't work here. It claims to not be able to find the phone at all. Did you run into this problem as well?
Alternatively, does anybody have the extracted nbh etc from that RUU exe? (I'm entirely on Linux, and had to temporarily borrow a friend's windows machine for it).
Ah, I was just directed to it by a friend, noting that it might work.That RUU as well as the guide are for the Magic. Currently there is no way to break the perfected SPL on the Dream if it has the E911 patch applied.
JTAG next week then, when I'm back at home and not travelling for conferences. Following your general concept there, you just found a newer legitimate update that WOULD apply, and wasn't actually blocking flash_image.
Updated my op (Update 3). I wrote an update script that should hopefully make for a painless root and CM install for both the Dream and Magic
gbd
Then my phone rebooted itself. What should I do from here?$ flash_image recovery /data/local/recovery-RA-hero-v1.6.2.img
mtd: read error at 0x00000000 (Out of memory)
---snipped for space---
error writing recovery: No space left on device
My phone is sitting in Android system recovery ... what now?D:\RogersRoot>adb devices
List of devices attached
000000000000 recovery
D:\RogersRoot>adb reboot bootloader
error: closed
Any chance GreatBigDog will update his script method for CM6?![]()
1) Best to follow the ROM maker of your choosing's directions. But keep in mind that our Rogers Magics are an Ebi1 device, so there is an additional kernel port for most roms to flash.
2) I hear SlideIT is pretty much as good, I think there are another one or two apps with the same idea available too. I am lucky enough to be in the beta for swype myself
3) I think our camera hardware just sucks, as none of the camera apps I have used seemed to be very good. That being said I use FxCamera and while it has some gimmicky modes, it's normal photo mode seems to work ok.
Wow, you're fast.
I read your comment in the 2.1 update thread about your concerns the Rogers update will lock the back door currently in use by the rooting community. I've been debating a CM5/6 change for a while, and this may push me over the edge. I like Sense, but I also like options.
In regards to item 2, I believe that swipe is in open beta now. Anyone should be able to get in on it.
gbd
The Swype Beta is CLOSED
June 2010: Thanks for your interest, the Beta is now closed.
Please register here and we will notify you when the beta re-opens.
The open beta closed in June. It was just for a limited days only. You can register on Swype for the next wave of open betas.
Swype | Text Input for Screens
