I've a Galaxy Mini running CyanogenMod 7.1 with build number lilG. I've a few problems with apps and battery life.
1. I have problems downloading apps such as Viber and WhatsApp which android market say aren't compatible.
2. Once I install Juice Defender I can open and run it but if I try to open the phone does a semi reboot from the cymd boot screen. If I try to start JD again it just reboots again and the only way to open JD again is to reinstall it. Any time the phone restarts I have this problem.
3. Last problem is that the battery life is after dropping a lot. If I have wifi on or even just txting a lot with wifi/data off it wont last a day.
Is there any updates that fix this or am I better off going back to gingerbread?
