NOTE! NEITHER I NOT ANDROID FORUMS IS RESPONSIBLE IF YOU BRICK YOUR DEVICE! GO THROUGH IT ON YOUR OWN RISK!
Here's the CyanogenMod 7.2 for LG Optimus Net P690!
Working features:
Fully working features:
> Everything!
> Yes, including Bluetooth, Camera, USB Tethering, Wi-Fi Tethering, GPS....everything!
Bugs:
> Offline charging works but not properly.
> Sometimes screen doesn't show up during incoming call
> Leggy graphics
Downloads:
ROM: CyanogenMod 7.2 by KD (Total download Size: 99.88 MB)
GApps, Fixes and Kernel (all-in-one):CyanogenMod 7.2 GApps, Fixes and Kernel (Total download size: 12.13 MB)
After downloading above files, put all zips on your root of SD Card.
You should have total 5 ZIPs on your root of your SD Card.
Instructions:
First your phone must be rooted and have ClockWorkMod Custom Recovery installed.
If it's not, you can go through this guide:
Guide: Root and install ClockWorkMod custom recovery on LG P690 (Optimus Net / Link / Spirit)
After rooting and installing CWM, you can go further.
Nandroid Backup
1. Boot into recovery by holding down Home + Vol Up + Power keys together about 5 seconds.
2. You must perform an Nandroid Backup, if something goes wrong, you can restore your phone.
(You can also revert back to Stock ROM by just restoring that nandroid backup. For more info, see the 'Rolling back to Stock ROM' section.)
3. To perform Nandroid backup, go to 'Backup and Restore' menu and select 'Backup'.
You should have at least 600 MB free on SD to store backup. If not free up some memory and take the backup.
4. After performing the backup, move the 'clockworkmod' folder to safe place from you SD like a PC.
Installing the ROM
1. In recovery Main Menu, select Wipe data/Factory Reset and confirm it on next screen.
2. Main menu > Wipe cache partition > 'Yes'
3. Main menu > Advanced > Wipe Delvik-cache > 'Yes'
4. In main menu, select 'Install ZIP from SD Card' > 'Select ZIP from SD Card' > Install all 5 ZIPs in this order:
(1) CYANOGEN 7.2.1 BY KD(C).zip
(2) GApps.zip
(3) FIX_1.zip
(4) FIX_2.ZIP
(5) NANI_KERNEL.zip
5. Reboot.
NOTE: It migh take some time to boot after installing the ROM because you just changed the OS of your phone! Be cool!
Rolling back to the stock ROM:
1. You must have an Nandroid Backup of your stock ROM.
2. Copy the backup folder 'clockworkmod' to your SD Card.
3. Boot into recovery by holding down Home + Vol Up + Power keys together about 5 seconds.
4. In recovery Main Menu, select Wipe data/Factory Reset and confirm it on next screen.
5. Main menu > Wipe cache partition > 'Yes'
6. Main menu > Advanced > Wipe Delvik-cache > 'Yes'
7. Main menu > 'Backup and Restore' > 'Restore' > your backup > confirm restore
8. Reboot and..... old home is back.
Original XDA Thread:
http://forum.xda-developers.com/showthread.php?p=24219195
KD and other developers, a huge thanks for your work.
Screenshots:
Working features:
> Everything!
Bugs:
> Leggy graphics
Downloads:
Instructions:
Nandroid Backup
Installing the ROM
(2) GApps.zip
(3) FIX_1.zip
(4) FIX_2.ZIP
(5) NANI_KERNEL.zip
5. Reboot.
Screenshots:
