Root CyanogenMod 9 beta
ZeRoseDev
How to Install CyanogenMod 9
First here are some helpful IMPORTANT tips:
1. You need to be Rooted. Guide HERE.
2. You need to have CWM. Guide HERE.
3. You should make a backup of your current ROM. Guide HERE.
4. You MUST backup your 3G(If you've already flashed a ICS or JB ROM, this wont backup your 3G). VERY IMPORTANT.. GuideHERE.
How to flash a ROM?
http://androidforums.com/fusion-2-a...any-rom-fusion-2-links-root-cwm-included.html
CyanogenMod 9 | Gapps
FM Radio is working on this ROM with SpiritFM Free. Link HERE.
Known Issues (Working on it)
-The bottom row of the keyboard is half cut off, you need to install one from the play store.
AdFree included - Instructions: (Gets rid of ads in free and paid apps)
**AdFree website, for free download or updated versions HERE
1. Open the AdFree app.
2. It will tell you "Update found" press Ok.
3. Press Skip when it gives you the options.
4. Press, "Download and Install hosts."
5. Reboot the device. (This works on all android devices)
6. Profit.
My SD Card fried because of a crappy adapter, so I cannot test this (or the other ROMs) with a bunch of apps. I am working on getting a new SD, if you want to help make that happen, you can hit that donate button down below. If not, no worries, I will get one eventually.
-No SD means I cannot take a screenshot, I will post some as soon as I get one.
Enjoy.
Want to help by making a small donation? You can do that HERE.
If you find a bug, leave a comment, or PM me.
:D
