Root Cyanogenmod-like quick settings ribbon without Cyanogenmod?
Lauris
Hi There
I recently bought a new phone - Samsung Galaxy s2 plus. I wanted to move to Cyanogenmod, only to find that the vibration doesn't work at all for the ROM for my model. Since I need that I stayed on the Samsung stock Jellybean ROM, and the only thing I really miss is Cyanogenmod's quick settings ribbon. Is there any way to replace Samsung's drop down power widgets with the way CM works?
I know there are some apps on Google Play that try to imitate that, but when you try to flip the panel, it comes back to power widgets anyway.
I would love to have the blue-ish Cyanogenmod interface in general (not sure what that's called), but I can live without that :).
