Root CyanogenMod Questions
zmauls
I flashed over CyanogenMod 10 to my HTC Evo V 4G from previously using the MidnightROMS. I really liked the look and feel of the ROM over all, but I had some key issues that I could not get past. The messaging app was completely different, but I guess I could deal with that. The real problems are that the battery went back to a bar instead of the number I got so used to, there was no camera app whatsoever, nor there was there any gallery app to view the pictures I already had on my phone. It's annoying. I almost immediately flashed back to Midnight, though the entire process took almost 3 hours. WHAT A WASTE OF TIME! If I use Titanium Backup and backup the camera, gallery, and messaging app, then flash CyanogenMod again, will I be able to restore those apps? The phone too, if I wanted? I'm not a fan of the CyanogenMod phone. Any help would be greatly appreciated, as Midnight has been causing random crashes and reboots. Thanks.
Did you make sure to flash the gapps that were needed for the rom? I know I once forgot to do this and without them, your phone will not have things like the camera and gallery.
ok so to change the battey icon: settings>system>status bar>battery status style, you will have some choices i like circle with percentage​
Might've flashed the wrong GAPPS, I used the (basic, I think) one for ICS. Is there a different option? If so, where would I find it?
Alright, got the right GAPPS on there now and everything is great. Just lagging a bit, not sure why... obviously using NOVA launcher, bad idea? Also, no screen shot option. What can I do about this?
