Root CyanogenMod ROM CM-12 Android 5.0.2
ironass
Extreme Android User
A couple of hours ago the first official nightly build of CyanogenMod for Lollipop, Android 5.0.2, came up.
There have been unofficial builds of this over the past month which have been a mixed bag of stable and unstable with certain features that were either missing or did not function correctly. However, this first nightly build, 20150106, so far has proved very stable.
This build is, so far, only for the klte, SM900F, International model. You should flash it via ktoonsez's TWRP Recovery after a FULL wipe if you are coming from any other custom ROM or stock firmware. You will also need to flash, via TWRP Recovery, the special Google Apps package,
gapps-lp-20141109-signed.zip, for this build.
I would strongly recommend flashing a stock Samsung NL9 build prior to installing this ROM so that you have both the NL9 bootloader and modem.
Be warned! This is for competent users and, as with all CM nightly's, they are beta, test versions.
For more information, see the xda developers thread... CyanogenMod 12.0 | Android 5.0 Lollipop
ironass motto... "Flash in haste... repent at leisure!";)
CyanogenMod CM-12, Android 5.0.2 unofficial is available for the following models...
G900* Unified-GSM for kltexx, kltelra, kltetmo, kltecan, klteatt, klteub, klteacg, kltedcm, klte
(install Phone Info, free from the Play Store, to check your, "Device Type:")
SM-G900i (kltedv) Regional model
SM-G900R4 (klteusc) US Cellular
SM-G900V (kltevzw) Verizon
Courtesy of albinoman887, one of the developers for CyanogenMod. See his xda developers thread...
Be warned! This is for competent users and, as with all CM nightly's, they are alpha/beta, test versions. Do read the developers thread, carefully and thoroughly, before flashing and take a nandroid backup before doing so.
The latest, "Nightly", official release, CM-12-20150121 for klte has added in Settings > Status bar > Clock style the ability to choose whether the Status bar clock is, Right, Centre, Left or Hidden. Check it out. :)
