Root cyanongenmod 7.1.0 little problem
Everythings working perfectly on this rom except the android market will not let me download anything. It comes up an error such and such can not be downloaded due to an error.
The only thing i can think of is the google apps zip i installed will not work for the htc desire cdma. So im guessing either i need to use a 6.0 g apps or do something else. Anyone know how to just flash 6.0 or whatever over my current zip so itll work?? Or do i have to wipe data/etc again??
I dare say this doesn't help much, as I'm on GSM, but I have the Gapps zip installed (I installed it when I originally flashed the CM7.0.3 ROM a couple of months ago - don't know if it has changed since then), and have just successfully installed an app from the market after having installed the official CM7.1 last night.
Yeah i dont see how that helps me in anyway...... Hopefully someone else can chime in and help??
There are two things that I can think of;
1. You declined the Market terms and conditions on first run.
or
2. You've simply had a bad flash and need to do it again.
or
You know come to think of it number one seems like the problem. I remember that came up when i started up the rom and i was going to fast to really care. I guess ill flash it again unless i can hit agree or whatever on the terms.
