Nsane1
Member
My mother just got a refurb D2G. Now it won't connect with the Ford Sync in her Explorer. When you put in the PIN that the Ford Sync gives you it says "problem connecting". I was wondering if this is a Gingerbread problem or a problem with her new refurb. When she got the GB push it killed her original Droid2 Global and she had to get a refurb so I don't know if the sync has worked since the GB update has rolled out. Thanks in advance for your help.
