Root [D320N] Key combo issue
Kimmyshor
The phone is rooted and i also have PhilZTouch6 recovery, but i still can't enter fastboot/download with key combo power+volume up in fact the combo never worked only the power+volume down witch enters in hard reset mode. And another thing i can flash anything from recovery, I tried some custom roms and another root it gives a package compatibility error every time.
I was thinking to flash it stock then try again :-? any other suggestions ?
You don't need key combo for download mode just keep holding vol up. While connecting usb cable from PC to your Smartphone and you will have download mode. And then flash the stock aboot, recovery, etc for fastboot mode to go back to complete stock. Cheers hope this helps.
