Root Daemon started..then
Ok, I've followed the instructions through just about every D4 root guide and I can't figure out what I'm doing wrong so ill list my steps for you guys so hopefully someone can course correct me..
1.Downloaded moto 5.5.0 with motohelp and installed it..which didn't seem like it did anything( windows 7 home premium 64bit)
2. Downloaded every one click root tool avaliable, they pretty much all do the same thing.
3. I open up the .bat file and click start, ensure my phone is plugged in and usb debugging is enabled, and it says daemon started successfully and then nothing happens no matter how long I wait.
If anyone has any idea or further questions, ill be checking this periodically. Please and thank you :)
Make sure your phone is USB connected in "Charge Only" mode. Pull down the menu on your phone when you plug in the USB and select "charge only" as the connection type.
