Help Damaged SD card
Xenxen
Hi.
So I was trying to do my laundry but my phone unfortunately fell in the water. Because of this, my SD Card is damaged. I would try to reformat it, but I don't want to lose all the photos stored in my SD card. Is there a way to fix this without reformatting it? All help is appreciated.
Let it dry then try cleaning the metal parts with a pencil eraser. Be sure you get off all the little rubber bits from the eraser before you put it back in your phone. Can't hurt, might work.
A microSD card is an inert storage media, there are no mechanically moving parts and electronically it doesn't have anything like a powered circuit board/controller board. There are the metal contacts you see when you turn one over and internally it's just non-volatile, solid state media. So if it's been dunked in water, if you let it dry out thoroughly (emphasize thoroughly, several times even), it should still be usable and will probably still have your old data on it. Note that if it was soapy water with say, food particles in it, you should rinse your microSD card in clean, preferable distilled, water. Then let it dry for a few days. Putting something like a microSD card in water isn't a problem when you're holding it in your fingers, it's not getting any electrical current.
