Help damaged software
Amrmaghny
hey there , hope everything is going well .
yesterday i had a notification for a new software update directly i pressed download and after downloading the new update the device started to install it untill 83% then its installation failure and the phone is not working just starting on android boot menu .
so what can i do please respond.
Regards
Amr
It looks like you are going to have to reflash your stock ROM (or some other ROM suitable to your phone). The good news is that it looks like you have a recovery that might allow you to flash ROMs from your SD card. I think for you the hard part will be finding the stock ROM to reflash. I'm not familiar with HTC phones so I really can help you find the correct ROM.
