GalaxyTDM
Well, I finally decided to root and oclf.
Used z4 root and all went well, applied oclf and after it re-booted it hangs at the splash screen then just goes blank, sometimes the options return buttons come on but then nothing.
IIRC factory reset is press and hold power, vol up and home key, but whrn I do this it just keeps flashing the galaxy s screen on and off.
Any advice is much apreciated.
GTDM
GTDM
] , or look for a way to get into download/recovery mode
and he'll send it off and see if they can flash the latest firmware to the phone.
But I asked them to get the 3BR working on it..so I can keep breaking it to my hearts content
