dark screen evo
  • Start date Start date
A
Android Question
Guest
I have an HTC evo. It worked fine earlier and now the screen is too dark to see anything. How can I get the brightness back up?
Hi!
Go to your settings and select "Display" from there you will find the brightness and can adjust it. If that does not fix your problem then it could be that your phones battery is getting too hot from heavy use. Hope this helps!
