Root Dastin releases CM 10.1 (4.2.1)
ENG Hboot ok with TWRP 1.1.1 ?
I haven't tested it with 1.1.1, only 2.3.3.0, and that version gets partition errors with the ENG hboot so I recommend the JBear 1.50.5050 hboot if using TWRP2 (touch). The best way to find out is to start the recovery and then check the log to see if it is reporting any errors with the hboot installed.
If you check the OP for the ROM, dastin recommends 4EXT recovery, hboot 1.04 and the latest Sprint firmware, which for VM users would be the 1.09.00.0706 version that came with the OTA. I'm sure other combinations of recovery, hboot and firmware will work but those are the developer's recommendations.
ramjet73
Upvote 0
thats a bummer .. since my initial backup is on 1.1.1, don't care for touch recovery and they no long offer the free version 4EXT on playstore.. why cant things just stay simple :)
You might still be fine with TWRP 1.1.1, it's just that dastin won't support booting issues unless you are running the recommended configuration. I flashed and booted it successfully with the JBear 1.50.5050 hboot, but I do have the current Sprint firmware and use 4EXT.
The only version of 4EXT available for the Evo 3D is touch, but you can still get it for free by downloading the Recovery Updater from 4EXT Development and installing it as an .apk, then use that app to install and update 4EXT recovery.
ramjet73
  • Like
Reactions: nerdmastax
Upvote 0
Thanks for the heads up! I will definitely give this a try when he puts out a VM build. By the way, on his latest CM10 VM build, I still get text notifications for voicemails (and no standard voicemail notification). Is this a known issue still? He had a changelog item about fixing VM voicemail, and I had assumed that was referring to this issue. I can't post in XDA dev section, or I'd ask there.
Upvote 0
ramjet73
Twrp2 works fine with the eng hboot... I've been using it with the eng hboot for months without a single issue.
Upvote 0
Look at the log file after you start TWRP 2.3.3.0. There are errors on the misc partition and the partition sizes are off from what they are with the 1.50 and 1.57 hboots. See http://androidforums.com/evo-v-4g-all-things-root/663486-twrp-2-3-htc-evo-3d.html for more detail.
Personally, I'd rather use an hboot like JBear 1.50.5050 that runs error free with TWRP 2.3.3.0.
ramjet73
Upvote 0
Would you recommend hboot 1.50.5050 over hboot 1.04 for the htc evo v 4g?
Yes, for day-to-day use.
If you check the partition layouts displayed by the "cat /proc/emmc" command the ENG 1.04 hboot has a different misc partition size and the one for the 1.50 hboot matches the stock ICS hboots. I've attached the output of that command for three different bootloaders if anyone wants to compare them. There are some partitions in the ICS versions that are missing from both the 1.04 and 1.50 hboots, presumably to support additional functionality.
The ENG 1.04 hboot was released during the development of the Evo 3D and there are later engineering versions but they only work on the development hardware version (HW001) and not the production model (HW002). If you want to know more about the engineering bootloader you can read this thread on XDA. Note the warning in the OP of that thread:
Now that S-OFF is available we can use the eng bootloader to get extra fastboot commands. If you set S-ON for whatever reason you must flash a SHIP bootloader first or you will brick your phone. If you aren't sure if you need this or not odds are you probably don't, it can be extremely useful but it assumes you know what you are doing so it is much easier to brick your phone with it.
Most of the fastboot commands that the engineering bootloader adds are supported by the custom hboots, and the ones that aren't are pretty dangerous, which is why I usually recommend the JuopunutBear GB 1.50.5050 hboot. My philosophy is to use the most current version that works and I would recommend the JBear ICS 1.57.5757/1.58.5858 version if it flashed and booted all ROM's. From what I've seen here and the XDA forums, the rest of the original firmware upgraded by the OTA works fine, so the bootloader is the only thing I would change, and only if you need it to flash and boot GB and/or AOSP ROM's.
ramjet73
  • Like
Reactions: badboytoast
Upvote 0
BEST TECH IN 2023
Smartphones
