##data# anything for beter wifi connection?
Do you mean when the phone sleeps the WiFi is dropped? If so, go to settings/Wi-Fi then hit the menu button and choose advanced. There you will see the setting for keeping Wi-Fi on during sleep. I have mine set to always.
Codegerm
No it just keeps cutting in and out all the time.it was fine instill I started using jelly bean.but I don't think its jelly bean, I haven't heard anyone else complain.
That is quite odd. I am running on FK23 stock rooted and am having no issues. What one are you on?
I just switched last night from 04 to 16, I can't remember if it was a problem on 23. My laptopstays cconnected no problem.
I know I should go back to fl23 and see how it is.lol,
I would say try first rebooting your wireless router first. I have run across issues of the router causing problems like that, with one thing is connected fine and something else having issues. If that don't work maybe a re-flash of the ROM may bee needed.
I will try that.
Rebooted router and that seemed to work, staying locked on now, thank you codegerm.
Cool, glad that was the issue. It is a lot less annoying to fix than re-flashing ones ROM. I use the self healing option on my router which does the same thing on a schedule. :)
