data canection android mobile
  • Start date Start date
As long as your contract supports mobile data, put the card in the phone, go to the wireless and network settings and turn data on, and that should be it.
If it doesn't work, check the "APN" (Access Point Names) settings in the mobile data settings are correct for your network - you should be able to get these settings from your provider's website.
