A
Android Question
Guest
Hi, I cannot seem to enable data back on, unless I turn airplane off/on, if the data was previously disabled by a battery saving application. Had Juice Defender, AutomateIt Pro, both face the same difficulty in re-enabling it from time to time, just to sync.
Anyone knows a fix for that?
Device is LG D686, Android 4.1.3, rooted.
Thank you very much!
