Root Data fails to reconnect on WiFi shutdown.
DNRDustin
Running Mate35. Googled a bit but wifi not working seems to be a bigger issue. What process would be associated with this issue, & what could be done to fix it?
I would reflash. At times if everything is not wiped and formatted (dont format the sd card) things such as wifi wont work. Hope this helps
I have the same problem on my device, too.. and I don't have the Mate35 rom flashed yet... my fix is to restart the phone. unless of course, it restarts on its own. which happens. a LOT. -.- <-- Grr face.
